'13 Tahoe - Front shocks easy to replace?
Ex Euro Driver
Hitting 50k miles and notice a little chatter up front. Going to start with shocks and go from there. Fairly easy job or is it a nightmare?
PaulS63
Not terrible, but the fronts are coil overs so you need a good spring compressor to do it safely.
BlackOh7on22s
In the Garage
Parts store compressor wont work, I used a wall mounted strut compressor to change mine. GM actually had a special wall mounted compressor for the NNBS struts for some reason
PaulS63
I used a parts store compressor, but it didn't grip the spring very well. Held my breath the whole time.
t.stimpson
i tried using a store compressor myself. scared the shit outta me and took it to a shop nearby. He only charged $40 for both. I guess thats better then losing a hand.
yates ™
Resident Apple hater
Iowa
Used the store spring compressors with no issues.
welfarewagon
Lexington, KY.
I just bought a set of the quick strut from Rockauto.com $99.00 each, made by Monroe with new strut and spring, swapped out both sides yesterday in less then 2 hours by myself. Its a lot cheaper then an ACDelco strut, they run from $112- $239 depending on your suspension set up and you still have to swap out the springs.
Ex Euro Driver
Ex Euro Driver
Awesome guys, thanks for all the input. Might just take the easy route and replace the entire strut
Padraig
I did the same thing. Piece of cake!
Padraig
Nix409
