Freedom Motorsports
- Joined
- Jul 16, 2011
- Posts
- 933
- Reaction score
- 20
NOW Through May 25th, receive 15% OFF R1Concepts Performance brake packages for Memorial day!
The R1Concepts Premier drilled and slotted rotors performance brake packages we offer will not only improve every day stopping distance, but will also eliminate brake fade in emergency stopping conditions and willl greatly improve the overall longevity of your braking system as a whole. The R1 Premium drilled and slotted rotors are cast from G3500 grade carbon metallic compound metal for extreme strength, coated with a military grade black electrocoat for corrosion resistance. Their drilled and slotted rotors provide the best all around performance due to providing the best cooling and gas reduction while braking and their exclusive diamond slot design improves pad bite, keeps the pads clean so that you do not wind up with friction material deposits on the rotors and actually improves the longevity of the pads because of that same reason. Their Posi Quiet ceramic brake pads are a low dust, low noise ceramic formula that offers great protection from over heating, a non metallic compound that is much less subject to glazing and is pre scorched to eliminate the need for lengthy break in periods upon installation.
