160 thermo. Heat spike at 107° weather.
ROGELIO A GUZMAN
ROGELIO A GUZMAN
Los Angeles CA
210 is normal for a tahoe. GM typically uses a 190-195 degree thermostat. This allows the coolant to stay in the radiator long enough to get cooled down otherwise with a lower degree thermostat the coolant just flows thru the radiator with very little cooling and actually cause you to overheat. Many people try a lower thermostat when looking for a overheating problem, some remove the thermostat entirely and then have worse problems. Water boils at 212 degrees, by raising the pressure in the system this temp goes higher. For every 1 LB increase you raise the boiling point 3 degrees so a 15lb cap will raise the boiling point by 45 degrees. 212 plus 45 equals 257 degree boiling point. If you are actually overheating then based on all the new parts you have you need to look elsewhere for a problem. But again 210 is normal and any increase in ambient temp will raise that accordingly.
I agree, I think I was Soo used to seeing my coolant temp around 160-190° in LA that when I seen on my torque ap 200plus I kinda freaked out. Now I see that 200-225 is normal.
Thatdesertviking
Las Vegas
I live in Vegas. The gauge right in the middle at 210 is totally normal for my Yukon and my Silverado.
In this climate I’m a stickler for making sure the coolant system is on point. Yours sounds like it’s doing good and even on the low side.
ROGELIO A GUZMAN
ROGELIO A GUZMAN
Los Angeles CA
Ok thank you for the feedback. I will definitely remove the 160 and go back to stock.
terryseverson
