1st time 2dr Tahoe owner
CWARE
Norman,Ok
A few weeks ago I picked up a 95 Tahoe 2dr 4wd. I’d been admiring them for a while but ran across a deal I absolutely could not pass up ($850). It has just over 228,000 miles but you really couldn’t tell by looking at it. The body is super straight but does have a small rust spot on the hood just above the grill on the driver side and the clear coat is peeling on the passenger side B pillar. It does seem
to have had a leak in the rear quarter windows for a bit as there is rust that can be seen in both rear wheel wells as if the water ran down there on the inside and was trapped there.
Other than that, I’ve replaced the brake light switch which fixed both the brake lights and the issue that didn’t allow it to be shifted from park unless it was started in neutral. Issues that still need to be addressed is a small exhaust leak on the driver side and what I believe to be the ac blend door and control panel. The ac control panel seems to go in and out and I’ve read they are the source of common issues on 95’s. The steering wheel also is canted to the left when traveling straight down the road. The truck doesn’t pull in any direction and tracks straight so maybe it just needs an alignment but we shall see. I’m pretty excited about it so far though. 7109c3d71c83e033df72870e6dc54dc7.jpge43b6a58ed72491ca9e040d7fd45f321.jpgb7b350cda97b176cf003e147f97259bd.jpg
mtl111
Arkansas
Wow!! You definitely stole that at only $850! Clean looking rig, congratulations!!
Sent from my SAMSUNG-SM-G930A using Tapatalk
mtl111
Arkansas
Interior has seen better days , but thats an easy fix.
CWARE
CWARE
Norman,Ok
Thanks! Without a doubt I got the deal of a lifetime. And the interior is actually pretty decent and clean all things considered. The only real Issue is the driver seat being torn on the edge and worn a bit on the seat bottom. The carpet isn’t actually torn it’s just the floor mat that’s worn as you can see in the pic.
Fosscore
Sweet score on a favorite around here. Like the blue. Usually see white, black or red. Have fun fixing it up along the way.
Real nice Cameron! Watch those tires though. Plenty of tread but they are dry rotted.
I reckon LMC Truck will be on your short list soon for parts!
tdmcpa
