I'm interested in this also as I will hopefully be lowering soon and I do carry a ton of camping equiptment and people often... And I tow a boat.
I do not recommend going too low in the back. Beltech springs are soft overall. Even with bags they are not as strong as stock springs.
Others may disagree with me.
YMMV
Jmho
---------- Post added at 07:46 AM ---------- Previous post was at 07:43 AM ----------
Thanks, guys. I figured everyone would say helper bags. How's the ride with air bags and rear drop springs combined? I understand it'll vary based on pressure added, but with them set just high enough to keep the ass end up where I want it for normal, everyday driving, what's the consensus on ride quality? Also, now that I'm thinking about it, I'm assuming I could also account for the small difference in height between the driver and passenger side of the truck by setting the pressure a tad higher on the driver's side bag.
At 5 psi you can't even tell you have them.
At 25 you have a really stiff ride unloaded.
30 is harsh and you feel lines in the road.
Don't do 35. Bags will blow fully loaded. At least one of mine did.
This is on 20s. 22 may feel slightly harsher.
---------- Post added at 08:00 AM ---------- Previous post was at 07:46 AM ----------
Also. On a side note.
Even though a lowered truck with bags can and will tow fine. Haul loads well. It is not the same "feeling" as being loaded to the maximum at stock height.
The truck will "feel" heavy almost slight stressed vs. Stock.
Again. This is MY OPINION.
You have 1/2 the travel in the rear springs. On Beltech springs the top 3 coils touch with the normal weight unloaded. You have like 4 windings worth left for travel. You load that up to the hilt and you have even less travel. Ride quality does suffer from a loss in coil travel.
Also. Airlift bags are inside a coil. When they are pumped up to like 25 psi........ what are you doing essentially?
You are "freezing" the spring and changing the rate, so it does not compress as easily. Does ride quality suffer?
Yes. IMO it does.
Its all what you are willing to give up to look cool.
