2 din....
zach2011
Platinum Member
Wrong section, but I know you have to buy the 2003+ dash surround and do a little modification the AC controls to get the double-din to fit. Very possible though.
Alextahoe
Alextahoe
Lawrence, MA
Sorry, new here! Can you tell me if there's a how to video somewhere or pics, can you point me in the right direction?
felixgun
Lafayette, LA
This is correct. You have to raise the AC controls about a half an inch to close the gap between the HU and AC controls if you have an 01-02 and by the 03+ dash.
I had an '01 Z71 Tahoe and the 01-02 model tahoe's have a 1.5 DIN whereas the 03-06 (same body style, different dash) have a 2 DIN. I first bought the 03+ dash but didn't want to modify the AC controls so I said screw it and cut my original dash perfectly for a double DIN and got it touched up at my local audio/auto shop to make it look more "stock"... it didn't look bad considering I cut into my dash... It BARELY fit my AVIC-D3 at the time but looked as factory as an aftermarket HU could get.
droppedHoe
Lawrenceville,Ga
no you dont... just simply trim your current dash.
a 03 dash will block the ash tray and most of the 3 power outlets
groundscr8pr
flaccid member
scarborough maine
yea.. you def dont need 03 parts. i used some spacer bolted to the side of the deck. the mount the radio lock keys fron the factory deck to the spacers. then locked it in the dash just like factory. you will need to do some measuring to get it centered correctly. then you can trim the dash bezal so the radio can fit through
Ced
does either 1 of you guys have a write up/pics on this? i have a 01 and ordered the avh-4200 but dont wanna get a 03 bezel.
Rubeng0315
