2002 5.3 intake manifold gasket replacement.
JonnyTahoe
Minneapolis
Has your rear main seal been done yet? If not... have fun one day! :devilfinger:
The rear main seal itself may actually be good, but the rear main cover often leaks badly. Unfortunately, you have to tear things apart just as much to replace it. Don't ask how I know!
Larry is the king of rear main's. I'm getting ready to tackle that this weekend. I watched a few vids about that damn Cover I'm sure that's my issue. Leak is really getting bad now.
R
R422b
Oklahoma
Its really easy once you pull the blown transmission. [emoji16]
Sent from my moto g(7) play using Tapatalk
JonnyTahoe
Minneapolis
I will have to call the dealer tomorrow because on RockAuto all I am seeing is wave or standard motor products. I try to use all ACDelco on my vehicle unless there is a better brand.
You may re-think the dealer when they quote you the prices. Good Luck.
Livebai8
Houston, Texas
No but once you have it pulled it is easy to change the rear seal. [emoji1787]
Yeah...thats on my list of shit to do also...dropped my front axle to do shaft seal on the right side and did oil pan gasket too...oil pan leak stopped bit the two skinny bolts leak a bit.
02 TAHOE LS 4X4
5.3l FLEX FUEL
285/70/17 W/Z71 RIMS
Sent from my SAMSUNG NOTE 5 using Tapatalk
JonnyTahoe
Minneapolis
02 TAHOE LS 4X4
5.3l FLEX FUEL
Sure don't want to over tighten those mine leak too.
