SO heres an update on my Yukon. Im still looking for answers! lol
Im still dealing with my limp mode issue.
Heres what I have been able to do since my last post. I have cleaned the throttle body and also disabled the ABS by removing the 60 Amp fuse. I bought a better scanner and I know its not my wheel speed sensors as i dont loose a signal for speed. I have narrowed it down somewhat. WHen it happens I get a check engine light at the same time and I check the codes immediately to find code P2135 (Throttle/Peddle position Sensor/Switch A/B voltage Correlation) if i have left the engine running it is idling very rough and when i clear the check engine light with scanner it will smooth out. But the Traction light will stay on and im still in limp mode. At this point I must shut the engine off and wait a few seconds then restart. Most times it will start and all lights are off. I may go 1/2 mile or 10 miles before it will do it again. Also another thing is that if I leave the yukon runniong sometimes it will go into limp mode sitting still. Ive replaced the module on the throttle body and also the switch that is connected to the accelerator pedal. Is there any other switches tied into this? I have done the Sync procedure but it doesnt seem to work. I have also had code P1518 (PCM to TAC module Data Circiut) as well. And a few times i have had P0120 ( Generic Current Throttle/Pedal Position Sensor/Switch A Circiut). One time I had a code P1516 (COmmand vs Actual Throttle Position Perfromance (TAC Module)) come up.
Can anyone shed any light to this for me? Appreciate your help as Id like to keep this vehicle around a while. When it runs without lights it runs awesome and handles my mowers and trailer great.
Thanks Rod.
Thanks Rod.
