2003 Tahoe P0342
Chevyman95
Hi can't figure this one out, I have a 03 Tahoe with 220k miles. I got a p0343 code so I replaced the camshaft sensor. Now I have a p0342 code. I replaced the connector wiring and it is still throwing the code on startup. Runs perfectly fine though. When I test voltage I have 11.5v on one and nothing on the other 2. Any suggestions? Thx
C
Chevyman95
Lol I was the one who bumped that thread. Guy never responded with his solution. Thanks though
SLCHOE
ASE Master Certified + (L1)
Midvale, Utah
There should be 3 wires.
With sensor disconnected and Key On Engine Off you should have:
12V on the RED wire.
Ground on the PINK/BLACK wire.
Plugged in with Key On Engine Running and back-probing the BROWN/WHITE wire, you should see a nice square wave on a lab scope. Not much you can do to troule-shoot this without a scope. You wont see the signal on a multimeter as the frequency is too high.
