no significant loss? that would indicate a slow leak, your going to have to go look for it, get under it with a flashlight, 05 should have electric fans so if you can't find anything obvious you might have to pull the fans and look behind there as well.2005 Tahoe has antifreeze smell upon start up. reservoir shows no significant loss of fluid. no fluid on floorboards nor on ground.
My Denali gave me fits. I was lucky and already had the Denali down hard replacing the front end suspension. While messing with the Tees to come off the heater core the heater hose with the molded in plastic male fitting that goes into the tee just broke off under the slightest tension. Plastic was dried out and brittle. Then I spent hours screwing with getting those tees unlocked from the heater core nipples. It took less time to knock the bushing out of the control arms!With basic tools, it was not hard to do the repair on the road...
I replaced a heater hose T in the parking lot of my barbershop one town away from home.
Screwdriver, pliers, snips and hammer were all I needed besides the new T and coolant...
New T had the snap connector on it, so there was no need to make the snap connector release in one piece.
I just snipped the plastic on the T on either side of the connector tabs and broke it away to release it from the heater core tube (gently, as to not damage the heater core...).
