Woodblocker55
- Joined
- Apr 13, 2019
- Posts
- 667
- Reaction score
- 419
Ac delco 21650 34 inch 18 1/2 1 1/16 [emoji106][emoji41]don't get confused with ordering a radiator, yours will be the 34" nothing else matters, doesn't matter if it has the engine oil cooler or not because even if the radiator has the oil cooler option it just wouldn't be used is all, makes no difference if it is 2wd 4wd awd, or if it has or does not have anything else. they all come with a transmission cooler port.
you can source a oem radiator cheaper than from the dealer at many places, just don't buy a cheap generic one and you will be fine.
I got upper and lower hose temp sensor and thermostat .. might need heater hose ..now to go green or GM stuff dex ..[emoji849] can I leave it green ? I seen bothers 2002 has same issue very small crack . He used dexcool the whole time so green or dexcool same out come it's the plastic. 185,000 miles only [emoji849][emoji15]
Sent from my LGL722DL using Tapatalk
