2Cool2Fool
- Joined
- Aug 11, 2021
- Posts
- 13
- Reaction score
- 23
I bought a zero rust, 170K 2007 Yukon SLT in June. I've fixed a number of usual suspects (new tires and wheels, motor mounts, torn seat, broken exhaust manifold bolts, etc.) - but what was bugging the hell out of my was the hard ride. In reading this forum, I determined that the most likely cause of the hard ride were the front struts and rear shocks.
My suspension code is ZW7 - so after shopping around, I purchased two of each of the following parts from Rock Auto:
- Front Strut assembly - ACDELCO 903040RS $104.00 ea.
- Stabilizer Bar End Link Kit - ULTRA-POWER K700538 $ 4.73 ea.
- Stabilizer Bar Bushing - ACDELCO 45G1673 $ 4.66 ea.
Drivers side took about 2 1/2 hours to install. The passenger side took about an hour less. (For less than $5 per side - you're crazy not to buy and replace the stabilizer bar end links. The stock links suck.)
The truck rides like a brand new vehicle. The 'hard ride' problem is solved! Since the rear shock are not leaking - I have no plans to replace them now.
