metelhead
- Joined
- Jan 30, 2010
- Posts
- 138
- Reaction score
- 43
First- Owned since day one, well cared for 295k. Tranny replaced about 100k ago.
Just recently noticed oil pressure sitting lower than usual...hovering around the 20psi (according the gauge). Historically this happens when low on oil, and a quick check and quart (or what is needed) is all that is needed to push the oil pressure around the 30's-40's.
Perhaps cause haven't been traveling much due to stay at home idk. But last week went on a day trip about 200miles and the whole time oil pressure was around the low 20's, would dip to 15 around idle. But no unusual sounds.
But the next day the Tranny coded, went into the limp mode, I checked for codes (P0700) and erased everything back to normal. P0700 is pretty generic, and I've had the stupid 'service trailer brake system' warning for the past year - inspite of changing module, every fuse etc... So I'm assuming this code was just more of the same.
Fast forward yesterday- went on a 200 mile drive (all fluids in order btw), half way through at stops or near idle the power steering stops working, but upon slighter higher revs above 1000 its fine. But the low oil pressure is again sitting around 15-22 all day. And again the tranny coded- same p0700.
Not sure if all three are related, but I'm guessing the low oil pressure and power steering are definitely related...Thinking I'm due for an Oil Pump. Just hoping its not more serious than that...
The tranny who knows, I've found the most of the warnings on these chevys mostly unreliable, and the number of interconnected dump sensors triggers has been the most frustrating part of owning and otherwise great truck.
So...any thoughts on the low pressure/power steering being related to an oil pump? Or is this a sign something more significant is up?
-could the tranny code fit into this puzzle too? Or likely unrelated?
