2011 Tahoe lt 5.3 waterpump replacement - SOLVED
Chvytahoe11
Been toping off coolant every 3 days for a week now. Couldnt pinpoint the exact location but it maybe the pump is on its way out. Im planning on getting it replaced some time this weekend, since its our only vehicle and need to drive it tomorrow for work. I plan on replacing the pump, thermostat and belts. Are there any special tools I need for this? How long should I expect this to take? Do I need to use sealant before i place the gaskets? How much coolant should I buy to refill once Job is completed? And are the torque specs 22lbs for the pump and 11 for the thermostat housing?? ( those are the Numbers that kept coming up on youtube). Thanks for any help!!!
Charlie207
LFOD, New Hampshire
It's pretty straighforward. Hardest part is making a mess, and maybe getting the two heater hoses off the right left of the water pump... they were sticky with age. You can do it in well under an hour, including bleeding the air out of the coolant system.
I didn't use any RTV or gasket sealer on the two gaskets that came with my waterpump.
The main serpentine belt is easy to get off, but the A/C belt is annoying. I got it off/on by hand when I swapped motors, but all the accessories were missing from the front of the engine at the time, and no plugs were installed, so the engine spun over easily. There is a small tool to help get the A/C belt to stretch over the harmonic balancer, but I'm going to try it by hand again next time.
C
Chvytahoe11
Thanks for the reply. Do you happened to know what the tool is called?? For the ac belt Removal? Aldo, are the torque specs i mentioned correct?
Charlie207
LFOD, New Hampshire
Welcome to the Forum from NH.
Pics of the truck, please.
mikez71
under an hour! dang I was gonna say 2 hours..
When I purchased a GM belt, it came with this tool..
I know I overtorqued my waterpump.
NOT saying you should, but that waterpump seemed heavy to be hanging off those long bolts at a measly 22lbs..
I didn't trust it so I gave it some extra :p
strutaeng
Dallas, Texas
What about the tool for removing the fan from the water pump? I use a 12" crescent wrench and wack it with a engineer's small sledge hammer or large deadblow before removing the belt, but I've been using no-seize on those threads. Those can be stubborn and may require a special tool if some sort. I think you can rent them at the local parts stores.
I used to put the thermostat/water pump on the pump gaskets because I thought the threads in the block went through something, but later found out the holes are blind, so there's no need for sealant and now I don't use anything.
Get yourself a small gasket scraper to clean the block mating surfaces.
I think I've used 2 gallons of the concentrated coolant. Maybe a little more. I can't remember exactly.
If everything goes well, you can probably knock it out in 2 hours, taking your time. It's really not that bad of a job TBH.
Try to avoid splashing coolant into the belts because that can cause them to start squealing...
The 2011 is electric fans, easy job for the water pump
Joe Hale
