2012 Tahoe 127k can now hear a gear turning sound @ 25-40mph - SOLVED
ILOVELONGISLAND
Hello
purchased 3 months ago, overall super clean had some issues , but now this ! When on a real smooth road
while coasting in the 25-40mph range, I can hear gears turning, as I slow down so do they........ Can someone here tell me whats happening ???
Hello
could be lots of things, you might try recording a video of the sound as best you can and then upload it to youtube and post a link to the video here.
youtube is free to post video's on
preferable to make a video longer than a few seconds, if you only hear it at a certain speed try recording (all one video) before that speed, then while at the speed, then above that speed and back down to that speed again until you fully stop
I
ILOVELONGISLAND
Its a very low level growling..... I called mechanic friend, he says it could be the hub bearing?? wishful thinking
possibly, 127k is a little bit early for a hub but not unheard of. If you determine it is the hub it is recommended to do both sides at the same time because usually one follows the other....
best to use a good brand or oem. acdelco, timken, skf.
the cheap ones usually do not last, but sometimes we gotta go with what we can.
Marky Dissod
Go to your trusted mech, have them put the car up in the air on a lift, and 'drive' it GENTLY, til you figure out where the noise is coming from.
If, after 20min of this, you still have NO CLUE where the sound is coming from, check the front wheels.
I
ILOVELONGISLAND
Thank you everyone...... Going to mechanics this morning... Hoping its just a hub bearing
will report what he finds here, thanks again
Geotrash
Dave
Richmond, VA
I would also be curious there is any difference between 2wd and 4wd. But hub bearing is a good bet. I had to replace one on my 2012 at around 135K.
You might also check to see if the shop has a set of "chassis ears". They mount under the vehicle during a test drive to pinpoint sounds like this to the source.
Put the truck on a lift, and get the wheels in the air. Have 1 person in the truck and put it in gear and accelerate to the speed where the noise occurs. Then, a second person with a stethoscope goes under the truck and listens along the drivetrain and finds the source of the noise.
Geotrash
Dave
Richmond, VA
Can't get this image out of my mind...
ToddYYC
