13_Metallic
- Joined
- Oct 6, 2022
- Posts
- 25
- Reaction score
- 13
Why do you want to get rid of the spacer? Is it not spacing? There’s nothing inherently wrong with coil spring spacers. They keep the factory springs and your good ride quality. I guess the only reason to change the rear is if you want a firmer ride.13 Tahoe with Z55. Looking for some options for the rear. Has the factory AutoLevel in the rear and has a 3inch spacer under rear coil spring. What could i put under it to get rid of that spacer
Skyjacker cr 30s right? @Dustin Jackson is a 3.5 and the cr25s are 2.5 right?13 Tahoe with Z55. Looking for some options for the rear. Has the factory AutoLevel in the rear and has a 3inch spacer under rear coil spring. What could i put under it to get rid of that spacer
