DrNick
- Joined
- Jun 25, 2020
- Posts
- 13
- Reaction score
- 4
Hi All. (Accidentally posted in wrong model year forum) 00-06
115k on my 13 LT z71 Tahoe. At the 100k noticed a bit of oil leak around valve cover and driver side plugs were black. Getting a bit worse on oil presence and some oil consumption, concerns in last oil change, although “within GM specs.” Truck still runs great.
The PCV might be misbehaving causing this leak and is part of the valve cover leaking . Can this (the pcv) be cleaned while the valve cover is off or should the valve cover just be completely replaced to get the fresh pcv and new gaskets/grommets on both? I will do hose too. Note, as far as I can tell in TSB, this truck should have the new ports. I think it said cutoff was 2011 build for the old valve cover PCV port ones.
will attempt both sides.
