2015 GMC YukonXL- Fox Coilovers
Nokturnal
Nokturnal
I’ll have to change my sig I bet it’s my last Denali I had. This XL has 18x9.5 with Nitto G2 295/70/18. They measure a quarter inch under a 35” and are 11.77 wide. Nitto makes them in a non LT that saved me a ton of weight and had an even longer mileage warranty. The tread isn’t quite as deep but I get the look for my highway cruiser and they weigh in at only 50lb which is crazy considering they’re 35’s. The LT versions of the same size tire are almost 20lb heavier per tire. My 5.3 will get up and go! I was so worried about it being an issue with the lift and big wheel tire setup but the forged wheels and non LT really make power and braking a non issue
Oh Kee Pah
MAINE
Yep - I thought you had put the 18s on. The rig is looking great!
The LT vs non-LT in the Nitto is certainly considerable weight difference. I totally agree with the decision - if you don't "need" the LT w/10ply then go with similar setup to what you are running.
ItstheHOFF
Henderson, NV
Nokturnal
Nokturnal
Ready Lift SST 4” and replaced non magnetic shocks with new Monroe for a softer ride. Monroe 139104 Front and Monroe 911506 Rear.
Short_Haul
Well… after reading through this and many other threads regarding suspension setup… I just pulled the trigger on my new kit…
Fronts
King 2.5” remote reservoir Coilovers
Rears
Arnott 3066 air shocks
Xineering OBD/SS magnaride delete kit.
maxpsi
Could you take some pics of where you had to trim to fit the 35s?
STORMIN08
he posted this, just above yours...see #135, YOURS IS #138
mckaywolf
