2015 Tahoe Front Washer Pump No Power
Nick Moore
I have a 2015 Tahoe and the front washer pump quit working. There is no power getting to the pump. I have checked the fuse and have power, there is a relay clicking when the switch is pressed and the pump has been tested and is good. The I traced the wire from the pump to the fuse block and checked it where it goes into the front bottom side of the fuse block and there is no power there. Are there two relays for the front, one for wiper and one for washer? If so, where is it located? I cannot find a way to access the underside of the fuse block. Thanks!!
OffBrandCornDog
