My 2015 Chevrolet Tahoe LTZ long term, real world customer experience. The purpose of this post is help others make an informative decision. Background: mechanically inclined, meticulous care of vehicles (hand wash and wax only), have owned 14 GM vehicles, including 9 new. This is my 4th Tahoe/Yukon. Purchased December 2014 sticker price $66,785.
8/1/16 - 32,548 miles – Reseated and glued plastic panel behind driver side window under warranty
11/18/16 – 43,062 miles, Replace AC condenser $1,116.16, Chevy dealership, later became a TSB
6/26/17 - 56,491 miles,New Michelin Tires all around $1,327.63
7/6/17 - 57,800 miles, Replace rear AC line $494.20, Chevy dealership, later became a TSB
7/21/17 – 58,112 miles, New Battery $191.34
10/9/17 - 65,000 miles, Front brakes
1/26/18 - 73,000 miles, Rear brakes
4/24/18 - 77,111 miles, Passenger rear shock locked up, replaced, personal mechanic $816.80
7/16/18 - 82,126 miles, Top of gas tank line leak fixed, personal mechanic $438.27
12/13/18 - 92,000 miles, Replace AC condenser again, personal mechanic $1,170.46
Commentary: As with all vehicles there are going to be creaks and rattles so I won’t list them. The navigation system and compass have not worked in two years. Research points to the external antenna design that might trap water. There’s an abundant amount of information, via internet searches, regarding the poorly designed AC system. See link https://www.carcomplaints.com/Chevrolet/Tahoe/2015/AC_heater/ac_stopped_working.shtml
The Magnetic Ride Control, might be an over engineered with over priced components option. Which like all mechanical parts will eventually fail and need replaced. My front struts are leaking and will eventually need to be replaced. Probably the most concerning issue was the leaking gas tank. Friction somehow rubbed a pin hole into the line on the top of the gas tank. Pretty difficult to notice until enough gas pools and runs over showing up on the ground. This is a potentially life-threatening issue that GM should thoroughly investigate. As you can see above, I replaced the AC condenser again. This time it was performed by my trusted mechanic. He also pointed out how the bracket assembly for the AC line replaced by Chevy dealership was incorrectly positioned. As I stated earlier, hopefully this information will help others when they begin searching for their next purchase like myself currently.
