2016 Tahoe/Temperature sensor
pepito4802
Hi I'm Omar and I'm new to this forum I've always went on forums to read issues I've had with vehicles I own ...this is the first time I join
I have a 2016 Tahoe ltz I replaced the temperature sensor because the fans were running full blast and the temp gauge was not moving
The fans are still running hing and gauge is not working what should I do next
buy another OEM sensor and verify the thermostat is not stuck
there is a rash of bad sensors out there
Thank you for the fast answer how would I check if the thermostat is is stuck
generally speaking you can just feel the radiator hoses both should feel approx the same temp after a drive, but if one is noticeably cooler that would indicate the coolant is not flowing properly. same if the heater is not blowing hot air and is only luke warm
P
pepito4802
Thanks I'm going to check that
P
pepito4802
The top ones hot bottom one is not really hot warm but definitely not hot
mohd33303
