2019 Suburban mid travel
RB_Trucker
RB_Trucker
Redondo Beach
The kit so far has been amazing, the ride and handling are excellent. Especially loaded down. I still have the sway bar disconnected seeing is was binding too much went i reattached it. It sits close to 3” without rubbing or binding issues and when in 4auto or lock there’s no noise from the CV’s either.
I have been on multiple 400+ mile road trips and off-roading and I do say I’m impressed. The rear is next for arms and remote reservoirs that’ll change the whole truck as a package.
89Suburban
Bull in the china shop
SE PA
Great thread man with all the pics and discussion, thanks for taking the time to post those.
Oh Kee Pah
MAINE
When I went with Z-71 springs and 2” spacer my factory roll bar wasn’t happy back there. It does make a bit of noise.
Really enjoying following the build thread. Looking great, and I BET it’s feeling pretty good too. Very fun to drive…
I have 4” lift and originally the OE MRCs up front and rear, but Fox coil overs now. I do have a tough time with tight turns in 4hi and auto.
Would you suggest removing the front sway bar?
RB_Trucker
RB_Trucker
Redondo Beach
thank you, the truck still feels pretty stable and rides I think better without the front sway bar attached, I have the rear factory one installed still with no issues so far. I also have cognito front links I haven’t tried out yet to see the difference driving.
RB_Trucker
RB_Trucker
Redondo Beach
Can you measure the amount of shaft showing when they are fully extended?
Also the length from mounting bearing to mount bearing (fully extended length?)!!
The length of shaft showing is about 8-3/8” and total overall from center on center is about 24-7/8” fully extended. These are for up to 1.5” lift, I’m putting a 1” shock extender to fit these properly.
Fifty
Huge thank you!!!
It’s great to get specs so people can make sure what’s out there fits!!
oem magnaride front is 4.25 travel and rears are:
Smooth ride is 15.55” and 7.68” travel.
Z71 is 15.55 and 7.95” travel
Z85 is 15.55 and 7.20” travel
Z95 is 15.42 and 7.22” travel
Arnott as3429 is listed at 14.92 and 6.18” travel
Arnott as3066 is listed at 14.73” and 7.2” travel
Kyb 15.27” and 8.26”travel
Kyb red 15.28” and 8.07” travel
Monroe max air 14.625” and 9.313 travel
ADS is a 9” travel shock. I’m trying to remember its collapsed length. (Use z71 or border patrol spring… stiffer vs softer)
Multimatic dssv is 15.25” and 10” travel
ToddYYC
