2021 Tahoe PPV massive oem brakes, 16"
cadieext11
Thanks so got a question you might have mentioned it already what rotors did you go with and if you could give a part number . I'm in the process of doing this setup on a 11 escalade and the only thing I'm missing is 1 rotor I had ordered the acdelco #84865905 rotors but one of them was on back order and now are discounted so I'm stuck with one rotor.
THarber
DYNAMIC FRICTION​
60447086 (604-47086)
cadieext11
Thanks by the way I did come across some dynamic friction pads that fit these calipers less then 60$ semi metallic. I'll post some pictures when I get home.
cadieext11
Here's the pad info and in the calipers got them off rockauto.
mingo8706
