22" TBSS Reps Question
Jmat
Southern Cali
Hey guys, I've received a fairly good price for a set of 22" polished TBSS reps. The guy I've been emailing with tells me that they will fit my 07' hoe with no prob, but when I asked him for the exact specs he came back with: 22x9 with +22mm offset. I did some searching here on the forum and it seems to me that most folks on here run a 30mm to 35mm offset. I'm a total noob when it comes to wheel offsets so my question is.. how will this +22mm offset look on my truck? Ideally I'd like the wheels to tuck in much like the stock wheels. Appreciate any advice!
yates ™
Resident Apple hater
Iowa
They will stick out a bit more but not much. I think they only come in a +22 offset so they will look like the others out there.
soulsea
Bar
They will stick out 8mm more than OEM ... it actually looks better, that's if you can notice the difference at all.
Do it! :)
Goodinblack
I Like Tacos
Dirty South
Do it :d
I think the stocks fit in too much.
So these would sit perfect.......
Jmat
Jmat
Southern Cali
Ok, got it! Thanks all. :cheers:
A small amount of "stick out" is passable and if it's going to fit like Sumo's truck, then that's a good thing... Just so I understand how the offset works... if at 22mm these will stick out 8mm more than OEM, does that make the OEM offset 30mm or 14mm or something else completely?
xBoostx
