22" Tire Life and Replacement
For those with 22s, how many miles did you get out of the factory Bridgestone Dueler Alenza?
If you've replaced them, what did you choose and why?
I'm in MN, so mine is 4WD and snow driving, etc.
Looking at Michelin Defender LTX M/S. Have just under 30k on my factory tire and they're about gone. I would describe my driving as "spirited" ;)
Dannydevito74
I saw these rims and tires from Fuel, can anyone tell me if these tires will fit a factory suspension with a 2” leveling kit in the front? If they do fit wil they rub and if they do rub how bad? Thank you in advance for all of your help!
chicagofan00
Arizona
I have 18’s and my factory tires last a tad over 36k miles. I’ve since replaced them with the Michelin’s you are looking at. The ride is a lot better but I have noticed a decrease in MPG with them.
In my experience, most tires from the factory seem to last 30-40k at most, no matter the make or model.
SK XL
I had a 2012 Yukon XL with 22” Dueler Alenza’s and I was really happy with the tires. I ran them to nearly 60,000 miles and I drive a fair bit of gravel. They were pretty much finished at that point and probably should have been replaced a bit sooner. I’ll admit that I’m not the best for rotating and had some alignment issues that probably shortened their life a bit too.
I replaced them with Toyo’s Open Country H/T and got about 40,000 miles out of them. Both tires seemed sure footed in our Canadian prairie winters and did well on the gravel too. I was obviously less pleased with the wear on the Toyo’s.
Just moved to an ‘18 XL with the 22” Duelers again and I’m hoping to get a repeat performance out of them. Definitely the best factory tire I’ve ever had.
Trbotime
Mine have just under 22k on them and they probably have 2-3k miles left before they are at the warning bars. They seem to wear out pretty quickly.
2015 Tahoe 4WD LTZ
BMPGBH
