22 Yukon ipod usb issue
dancastro
Trying to connect a 6th gen ipod touch thru the console and the arm rest usb. Infotainment tells me "no usb device connected"
Tried it on friends 22 Sierra & 22 Camaro....connects fine.
Is there something in the settings I'm missing in setup??
TIA
WalleyeMikeIII
Sunny and Snowy Minnesota
TIA
Try the USB under the center stack, near the wireless charger; just to confirm it works. The manual implies the one in the center console is also usable for data...but, the same manual also says there is still an SD card slot in the center console too...and there is not. Wondering if upon remove of that slot, the USB in the center went to charge only. I can't test it, because when you get a sliding center console, you lose the USB ports in the console (no clue why).
Excerpt from pg 153 of the Denali Manual
pdrahcir
