26's rubbing like crazy, questions?
HokieHigh
Seattle Wa
Just put my 26's on with 305/30/26 and it rubs like crazy. I have a 3/5 drop kit. My question is would it be a horrible thing to yard out most of the plastic fender liners to make them work or is that a bad idea, not opposed to cutting out all that plastic out. What are the pros and cons to yarding out all the fender liners?
Alex33
I'm not sure about the negatives. Some guys just remove the plastics all together.
Modded
That Guy
There are no negatives to removing the liners completely. I would just pull them out if I were you.
H
HokieHigh
Seattle Wa
i didn't think it would be an issue but wasn't sure so i thought i would ask the people who would know for sure. thanks for the info, i think i will just take out the rears and go from there. appreciate the help
waxworkz
on the front left, drivers side, be careful of the washer bottle. i have 22s and i almost rubbed it completely through. i can say your engine bay is gonna be dirty as hell. unless you only drive on sunny day, expect to get dirty
Hammer450R
Did you try to heat it up and pry a 2x4 in there to make more space.
H
HokieHigh
Seattle Wa
I only have to yard out what little liner is in the rear, the front doesn't rub that much only on sharp turns
d!!!
I know most people run a smaller tire on the 26 the next size down from what you are Runing
z8891
