scottbrew92
I have a 2015 Yukon Denali 4x4 and have found some 285/55/22 Nitto Ridge Grapper tires. I know they’re a couple inches bigger than the 285/45/22 so will a 2in. leveling kit clear these tires?
Do you have the factory power steps?I have a 2015 Yukon Denali 4x4 and have found some 285/55/22 Nitto Ridge Grapper tires. I know they’re a couple inches bigger than the 285/45/22 so will a 2in. leveling kit clear these tires?
If so you will have rubbing on the end of the steps. I test fit some 305/55r20 and they would not fit when turned. 285/55r22 are even larger. I have seen people with amp steps having better luck because they don't extend all the way to the fender well.
