3/4? belltech... not happy
nkldime
Just got my 04 AWD yukon lowered with hopes of having a nice tuck look. I explained and showed pictures of how i wanted it to end up and went with the BELLTECH as my company to go with. After i got my ride back i went through my recipes.. punched in the P/N for the springs they ordered and on and the specs , they only show a 2.5-3.5 drop in the rear.. not gonna be enough .. there is still 2.5" cap between the tire and the wheel well. not digging it.
QUESTION- and ya i looked around a tad- but i need a answer before i take this thing back to them tomorrow... I cant find Belltech 5 or 5.5 drop springs for my gmc... the 3/4 kit they installed is not what i hoped and i need to convince them to order new springs for the rear and turn the torsions down in the front. :flame:
Alex33
Add some 3/4 ton keys or spindles (whichever you don't have) and belltech 140-002 springs in the rear. The springs will show up as a trailblazer 4" drop spring.
mharders
Just outside of Seattle
Well IMO, your not going to tuck with a 3/4 drop. Im running the 5305 coils on 24's and still have a large gap between tire and fender well. If its the 5305 coils, did they install the 1" spacer? Also with the autoride suspension it will sit you higher. There are a few things to get you lower . You could Remove the isolaters and get some drop shocks in the rear to replace the factory autoride and should sit you 1-1/2" lower. I dont believe you are going to get the desired look on the set up you have now if you wanna tuck the rear. What size tire and wheel are you running? Check out the guys rides above^^ and you should be where you wanna be, there trucks are LOW!
dylansmashed
