33/12.50/22
scottbrew92
South AL
I’m going to level my 2015 Yukon Denali and considering putting on 33/12.50/22 Nitto Ridge Grapplers. Anyone put this size on their vehicle…I do not want any tire rub.
STORMIN08
wheel spec is the most important key...high offset rubs control arm, low offset rubs the body.
i like using stock wheel as a base, wrap the tire with a piece of 1" foam until desired diameter and width...lifting suspension keeping it compressed, and rotate the assembly while turning. you can use a flat washer behind the wheel to adjust to desired spec, then order what is needed to make it work.
nick14226
eod_tech
