8.5 inch rim. no balooning @35 psi. I am usually light (just me in it). max psi on the tire is 65 psi w/ a load of 3195lbs.
I did the chalk test and it appeared that the tire was loaded evenly. Then I went up the 42 and the chalk test appreared about the same, though the ride wa a little more harsh.
I found a calculation over on another site that determines the ideal pressure based off the tire's max load, the vehicle max weight, and the tire max pressure. It came out somewhere around 30-35 psi....which seems kind low to me.
all of the "tests" seem inconclusive or incorrect, so im here asking for opinions
