3rd Row, passenger side seat stuck
llllljrlllll
los angeles
I have a 07 LS question regarding my 3rd row seat being stuck, it happened last week. I tried to take it out like i would normally would, but this time it's stuck. I can't fold it down to pull it out. The lever that makes it fold, doesn't go up all the way. And because of that, the pull out lever to take the whole thing out, wont work either. Since I need that 3rd space to carry my sons bikes and scooters. The only one that works, it's the driver side 3rd row. So you can imagine the pain in the a** it is to only have one working. once again thanks for taking the time to read this. any advice would help.
Xowner
Cincinnati
Can you see anyting down under the seat where it hooks to the truck? somthing stuck in there? like a toy bottle cap or somthing else? Just so i understand the seat is closed but folded foward just befor you pull the number 3 latch and then pull it out?
L
llllljrlllll
los angeles
I already checked to see if there was anything stuck in there, and nothing, it's frustrating. the seat is actually in the upright position, in the seating position, and i cant fold it down. i'm assuming that if I was able to fold it down, i might be able to take it out. Or at least thats what i hope. thanks for answering
L
llllljrlllll
los angeles
Originally Posted by m332is View Post
I understand. From behind the seat (cargo area), pull back towards you on the top of the seatback. It won't move much, but if the catch is hung up it should take the pressure off the catch. At the same time lift the little lever at the bottom to get the catch to release and while the lever is still in the up position, you should be able to now fold the seat.
The key is to pull it towards you and at the same time then lift the lever and push forward.
Vince
---------- Post added at 10:39 PM ---------- Previous post was at 10:37 PM ----------
For those looking for an answer on the seat dilemma, Vince solved it for me. I finally got the seat unstuck, there was some coins stuck on the catch.
pistolpetem9
