3rd row seat removal Premier Edit:deck added
Dave Jr
South Florida
Tools needed:
15mm socket and ratchet
Small screwdriver
Start with removing the accessory tray:
Remove Matt
Remove “thumb” screws
https://www.flickr.com/gp/163893409@N03/13jcz8
https://www.flickr.com/gp/163893409@N03/3fw880
After removing screws simply lift out container
Remove the aft 4 10x1.5mm hex bolts (silver) using 15mm ratchet.
***Raise the seats
Remove 3 access covers and 3 forward retaining bolts
https://www.flickr.com/gp/163893409@N03/Qr2Y70
After bolt remove I replaced the covers
***Lower the seats
Have your screwdriver handy and roll the seat section up
https://www.flickr.com/gp/163893409@N03/WT98d8
Unplug the electrical connection lifting the tab with screwdriver
https://www.flickr.com/gp/163893409@N03/0dhW4N
Your all set! Remove the seat assembly
https://www.flickr.com/gp/163893409@N03/AiJ23r
I will be adding a proper deck with spacers I’ll add to this post
Just remember to bag your bolts and wrap the seats for storage...
For now a weathertech insert works fine
cardude2000
Impressive. Nice work and great pics.
Now you almost have as much room as a small minivan! ;-)
Undeserving
Mitch and Murray sent me.
Triad Area NC
interesting. Not sure I am ready to remove my rear seat but would like to flatten the rear cargo area. It seems to me that the under cover storage are is about useless for anything othern than stashing a couple of pizza boxes and that it slopes to the rear hatch. Can you just remove the storage area and be left with what looks like a finished flat floor???
Dave Jr
Dave Jr
South Florida
My biggest hassle was the slope aft, not to mention the height. Was surprised how easy seat section came out. Worth taking out for day to day driving and installing in the rare occasion you need it. Just ordered the plywood to make a deck. I’ll post dimensions, bolt locations, spacer heights and such.
Dave Jr
Dave Jr
South Florida
Deck added, quick post will add more legible dimensions later
Tools/equipment needed:
3/8 plywood 48x40 inch
T45 torq to remove seat belt retainer
5/8 hole saw
6 10x1.5x60mm bolts
Hot glue gun or double sided tape
Fender washers
7/8 inch spacer material
1/4 inch spacer material
302F7BDE-5963-41C0-A829-B8195DD62B8C.jpeg 5342E7AB-D726-4439-8C8A-0249C1AFB097.jpeg
Basic dimensions
Showing holes, made it pretty close. Will refine the dimensions later
Dave Jr
Dave Jr
South Florida
Tuck the plug for the motor control under the trim panel
I used a hot glue gun to secure the spacers. Double sided tape works too. I used cut-offs from a bushing project using a lathe and some scrap teak.
D5C90B6A-5A25-4ABD-9FBE-7583C76AC39E.jpeg 38286DC9-BC28-424D-AD62-A8FE9985C2E3.jpeg
BEIS
Just an idea: maybe get a piece of carpet (like the rest of the truck) cut, and bolted down, then the Weather Tech mat on top. That way, you won't catch/rip any objects in the back placed on the protruding bolts. Also, this would enable you to easily dump out/clean the removable mat (instead of having to unbolt it like shown). Just an idea, but I really like what you did here. Great job!
Dave Jr
Dave Jr
South Florida
I’m probably going to go with some cup style or counter sunk washers to put a positive hold on the liner. When I have my tools in the back the liner slides all over and winds up folding.
But your right, a flush solution is better!
Something like this with a plastic cap
Undeserving
Triad Area NC
Was the ops vehicle a swb or lab to begin with? The behind the 3rd row space has me guessing swb
tanguycryms
