4" Lift with 33" Duratracs
massivespl
I'm not mean, I'm honest.
Michigan
What size 33? Like a 275/60/20 or a 33x12.50x20?
With the 275/60/20 u could do a 20x10 with like a 0 offset or higher I think would clear fine maybe little plastic trim...
With 33x12.50x20 prly a 20x10 with a 20-30 offset other wise lots of trimming/cutting
Dave k
Dave k
I am running 275/60R20 duratracs which offset would let the wheels stick out just a little?
Dave k
Dave k
20x9 0offset
20x10 0offset
Both those should be just alittle bit of the tire sticking out pass the fender.
Ok thanks I appreciate it I will post pictures when it's all done
01Konvict
Boats n Hoes
Raleigh/SML
So I am going to be lifting my Yukon with this lift kit http://supremesuspensions.com/produ...oe-suburban-gmc-yukon-full-lift-leveling-kit/ is there anything else I'm going to need like shock ext. or any thing like that also I will be running 33" duratracs on 20" wheels what offset should I look for? Also will this kit be ok with the rear air suspension? I have a 2007 Yukon XL with the rear auto ride
You can't lift the stock front end 4". Max is 2.5" and above that you def need UCAs plus diff drop. Shocks you need extensions for the rear and if your keeping the air ride then need RC ones from the 3.5 kit. Front shocks are ok as spacers mount between them and truck frame. What do you really want to do with the XL and I will direct you? If you want 4" then I would look into the RC 3.5" kit and all you need is longer all thread or FTS ride height spacers to reset the air ride sensors.
Dave k
Dave k
The kit that I ordered is a 3.5" lift in the front and 3" lift in the rear using spacers I'm really just going for the looks i don't take it off-road unless I have a reason
01Konvict
Boats n Hoes
Raleigh/SML
Better get some new UCAs cause anything over 2.5 sits on droop stops. Or be super sketch and cut the droops off the frame. Curious to know how long the CVs and tie rods last at those angles.
Dave k
Dave k
Well got the lift in and I am very happy with how it came out now I have to get my tow mirrors and new wheels onimage.jpegimage.jpeg
jason05
