4bt cummins swap
Bigvern55
So i have decided to go another route with my tahoe i get horrible gas mileage with the cam on the 5.3 im thinkin of dropping a 4bt cummins with a turbo400 tranny the 4bt 3.9 litre puts out 105hp and around 250fpt but with alittle upgrades like injectors and turbo i can push 350-400hp has any one dome this swap any ideas of how to tackle this chore
livingez_123
Sandy, OR
Why a 4bt when the 6bt will fit just fine?
if it was a jeep or some other type of rig the 4bt would be fine. but not for the Tahoe/Yukon. I put over 600k on my 97 Dodge with the 6bt and I had the plate about .050 forward and some other tweeks and it was perfect for what I used it for. I have thought about putting a 3rd gen Common rail in my Denali for some time now.
Donnie Yukonie
Yates Caretaker
x2 with the 6bt , I know its been done on our older models , but haven't yet seen the NBS with one , this is a long shot but have you tried contacting Duraburb to see if they will even give you any hints?
B
Bigvern55
They sell the bell housing motor mounts and all the pieces to put it together i was gonna do the 1st gen its less electronics and i figured doing the 4bt cause its a few 100lbs less then the 6bt so i figured itd be easier on my front suspension components and i already have the bigger injectors injector pump for the 4bt and a turbo from a 6bt wich should bump the hp from 105 to around 3xx the turbo is a bit bigger
livingez_123
Sandy, OR
try and find a 96-97 12valve that had a 5spd behind it. They were rated at 215hp and 440ft lb. I moved the fuel plate forward about .50 and adjusted the afc. all with the stock turbo. I put 600k on my Dodge running across the US and it never let me down. And it's much better than the 1st gen with the VE pump. the early 2n gen had the P pump. much better and more durable and you can get much more power out of it. Don't be afraid of the 3rd gen with the common rail and the computer. it still is a simple hook up. After driving the Dodge with the Cummins in it. my 97 with over 600k and my 04.5 with 260k You will not be happy with the 4bt. like I said earlier, if it's a jeep or other small vehicle, great. But not a 5-6k lb Tahoe.
dcwhybrew
Ditto...I think you'd have a lot less trouble dropping in a Duramax/Allison of the same/similar year model than putting a Cummins diesel in. Probably a lot less "re-engineering" work. The diesel place forum has a "Frankenstein" sub-forum that discusses this ad naseum. Look for a user name TDIGuy (Eric Swanson @ Duraburb).
Gzes
the drifting 2dr
Wichita tx
Should donate that 5.3;) i have thouht about dropping a cummins into the hoe. It had the option for the 6.5 if it did have it i woulda done it but its 5.7 so na
Duramax05blk
NH
Duramax is only a plug and play swap if your 03+ didn't notice what year you have.
MrsMfcknMcDonald
