4l60E does anyone think its the sunshell please help!
kaej
07 chevy tahoe ls 4.8l 4l60e trans
gears shift easy up and down fine but after a few secs of driving its like the gears dont catch? i heard a loud knock on the bottom like i ran over something before i started having the problem it drove fine for a week but then after a right turn on a slight deep the car wouldnt move its been three weeks since then and i haven't drove it since.
i checked the other day and it moves but i didnt wanna cause anymore damage so i just left it. i read alot about how the sunshell are the cause of the problem and how some people just replace that in there trans mine has 83000 miles my question is has this same problem happen to anyone and was it the sunshell i been thinking about getting the beast sunshell and see if the trans will work after that let me know what yall think thanks in advance!
Zed 71
Pacific NW
Go have it checked out. No way to know what the problem is by your description. Our 4L60E took a dump at around 50k and it turned out to be a sprag that was covered under warranty.
Good luck.
imi4tth3w
Texas
if its still under warranty, i'd definitely go that route. worry about a nice rebuild once your out of warranty.
K
kaej
no warranty just got it 6 months ago but i just drove it around the block in 3rd and it didnt give it keep goin and i tested it in my drive way P R N D 3 2 1 all worked fine!?? im scared to drive it to get it hooked up the tech2 at the chevy dealer as ironically enough when my car broke down i had to push it in there then have it towed to my house wouldnt want that to happen again..but has any ever had this happen to them?
Goodinblack
I Like Tacos
Dirty South
@ kaej, not to be a *****, but please punctuate.
This seems like a mechanical problem with the transmission, I do not think they are going to find any codes per say.
What you described happened to me in my 1992 Ford Explorer. The knock etc.....
One of the planetary gears comes slightly loose and hangs up, then it binds, and "knocks" back in position. The truck then drives fine, till it all goes.
The last place I drove my truck back then was to a dealership. I traded it back then for my 1996 Tahoe.
If I was you I would drop the pan and see what you find first.
southboundchicken
Jacksonville fl.
i was told by 2 different transmission mechanics that when the sunshell bites the dust you will lose 2nd, 4th, and reverse. with the mileage you have most trans shops are gonna want to do a full rebuild as to get into the trans far enough to replace the sunshell you might as well as freshen it all up.
GM Customer Service
Michigan
kaej,
I agree with "Zed 71", please consult with a certified technician for additional assistance. They should be able to provide additional information after an inspection.
Please feel free to contact me privately if you have additional questions.
Louis
GM Customer Service
Caddychris
