99 2 door
- Joined
- Oct 26, 2013
- Posts
- 5
- Reaction score
- 0
It has happened twice now.
4wd service light - P1875 came on out of the blue. This causes the truck to run horribly. Almost stalls going into 2nd and 3rd gear. I have to put in drive out of OD so it isn't so bad bogging down.
Service Engine light comes on couple of days later - P0161 O2 sensor heater circuit
Goes on for a couple of weeks (not my daily driver) then I hear a light click near the steering column and service 4wd light goes off. It runs like a champ, goes into 4wd with no problems. I wondered what the problem might have been.
5 days ago it pops on again and the entire above happens again and it has been a week.
I was going to start with replacing the 4wd switch, but noticed that there is a 4wd selector switch connector and 4wd actuator connector as well. Should I order all 3 and replace at the same time?
Has anyone else experienced this issue? What I temporarily pull the fuse for 4wd while I try to figure out - any collateral issues?
Thank you for the guidance.
