My first thought is a bad wire shorting.
But check the fuse make sure it's the correct size. (do not replace a 10 amp with a 15 or 20, etc...)
You may have to pull the plugs and start testing wires.
I would need a wiring diagram, but a ground would well ground.
A power wire however should not, and would indicate a short if it does. So check continuity to ground on the wires. Could be wrong but sure you should have 1 ground.
