5.3 03 yukon magnaflow ypipe and exhaust fitment on 6.0 03 denali
solidrk881
I have a 2003 Yukon Denali and replacement cats are crazy expensive and turns out to be 2 seperate down pipes vs a y pipe. Found it cheaper to get the 5.3 magnaflow high flow y pipe and 3in 5.3 single passanger exhaust. Anyone know if there might be fitment issues or lining up with the hangers and stuff? Hopeing not but I have a buddy with a TIG if it does have fitment issues.
Magnaflow 93419 y pipe and 15665 MagnaFlow Cat Back Performance Exhaust
jough
Arkansas
I wouldn't do this. Get the correct parts, even if you have to get used ones.
The 2 separate y pipes on your 6.0 likely flow better than the 5.3 one piece Magnaflow set-up. The only way I'd do it is if I could pick up the parts pretty cheap and I was already throwing cat codes.
People are always trying to find the Denali exhaust to install since it flows better so I'd keep what you have and just replace the cats. I just did mine and they were $600 for the high-flow Walkers installed. That's not that bad.
Con3600
