Thiis bulletin is primarily for the 6.2L.
"The bulletin also indicates that the above fix only applies to the following 6.2L GM V8 engines:
L87,
LT1,
LT2 and
LT4. For all other current GM V8 engine RPOs (
L82,
L84 and
L8T), the service department is instructed to “just replace the affected valve spring,” and that if they determine there is a cylinder leakage, it “will be necessary to inspect further to determine the extent of the engine damage to determine correct repair required.” GM is also requesting that the service department send back valve springs from affected engines for further inspection.The bulletin also indicates that the above fix only applies to the following 6.2L GM V8 engines:
L87,
LT1,
LT2 and
L82,
L84 and
