What’s your alcohol content?
Good thought and maybe, what the virtual ethanol sensor thinks is the E%?
If it is an injector I will be replacing all 8If you have ever bled the rail after a shutdown, there isn't a ton of gas that comes from the rail, a half of a tee shirt will absorb it easily. Looking at the plugs for leaking injector gasoline soaking them likely isn't going to help you. Also, the intake valve is closed a lot more than it is open, so gas may not even make it down into the cylinder, depending on where the engine stops, in enough of a volume before it evaporates to cause the plug to be reliably soaked and detected when you remove it. Finally, if it is a leaking injector and it is soaking a plug, Murphy would make sure it was number 8...
If I was convinced it was a leaking injector, I would be inclined to take all eight down to a shop that specializes in testing and cleaning. At 200K, if I did have a leaking injector that didn't stop leaking after cleaning, I would be inclined to replace all eight, but that is just me.
