Can a 6.0 lq4 from 2002 escalade fit into 2004 tahoe 5.3 without any modification ?
I used only the 6.0 block and heads and swapped over my exhaust manifolds and intake and accessories. I used everything from the 5.3 on the 6.0 even used the 5.3 Ecm. I up graded my tranny to the 4l65 but yes it lined up fine. I researched for a year to make sure I had everything I needed but there was no need. It's a quick and easy swap. It took me two days but spread over two weekends and I did motor and tranny.did it fit exactly on the transmission bolt , i think i have the 4l60e trans did you use the 5.3 ecm or the 6.0 dcm?
