Disclaimer: Links on this page pointing
to Amazon, eBay and other sites may include affiliate code. If you click them and
make a purchase, we may earn a small commission.
I think there are threads on this somewhere for better info, but hopefully someone else will chime in. It was a topic recently if I remember correctly.
I've been seeing this question asked across the forums and have been thinking about it. While not 100% sure, I do believe you are correct, that switching over the Techm and valve body from the 2011 to the newer case will be fine. There might be an issue with pump compatability unless they are identical.
Have you picked up the 6L80 repair manual off Amazon?
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
