7 pin connector trailer plug
Dimbagbubba
Looking for 7 pin wiring diagram that doesn't have a white wire as the ground. My 2003 tahoe factory 7 pin trailer plug doesn't have a white wire.
Dimbagbubba
Dimbagbubba
Idk yet but its a helluvalot closer than anything I've seen on the interwebs in the last 4 hours. Thanks. I believe it'll do the trick. First thing I've seen where a white wire isn't the ground.
Ima try it when the sun and temp rises a lil bit
Fless
Super Moderator
Elev 5,280
That diagram appears to be the harness connector that will attach to the back of the actual 7-blade connector that's on the hitch.
EDIT: from Rock Auto
Dimbagbubba
Dimbagbubba
They are the exact same colors as the wires that go into the back of the "actual 7-blade connector" that i plug my trailer lights into. Fingers crossed they work. Going to look good mounted to the left of the license plate!!
Fless
Super Moderator
Elev 5,280
Are you wiring direct to the 7-blade connector, or just re-doing the harness connector?
Bigine88
