92 yukon steering column lock cylinder
crmzendrgone
M town Arizona
does anyone know on a 92 yukon steering column lock cylinder how to get it out. do I need to pull the steering wheel off? and such????
crmzendrgone
crmzendrgone
M town Arizona
Well I figured it out.
I was thinking of doing a write as I went along but, ehh.
Anyway definitely need a steering wheel puller master set so you can compress a snap ring which is holding the lock plate on. after that it is pretty obvious so. . . .
Thanks for the views, hehehe.
ScottyBoy
Shreveport, La
Yeah, all of those round GM columns are the same. You have to remove the wheel, then compress the lockplate, then pop off that snap ring/retaining ring that holds the lockplate in plate. Then once you get the lockplate off, you have to move the turn signal mechanism out of the way by undoing 2 screws. Then you can access the screw that holds the ign switch in. Some are a phillips screw, but most are held in with a star drive screw.
crmzendrgone
crmzendrgone
M town Arizona
I had to learn the hard way. I mangled the snap ring taking it off. I didn't know that there was a spring under the plate so. . . but when I went and got the knew lock cylinder the guy was like "how did you get the plate off??. . . "I just used brute force." the counter guy ow-wow-shock-surprise-smiley-emoticon-000325-large.gif.
Luckily the near by Chevy dealership had one.
So yes all your steps are true and my bolt was the torx head style.
stakerd
