94 to 99 interior
white_lexie
I have a 94 Yukon gt and found a guy parting out a 99 Tahoe, will his interior door panels fit my 94?
Donnie Yukonie
Yates Caretaker
they will , Matter of fact the entire interior can swap over if you put enough time into it , the biggest issue is the Cluster and controls of the newer truck.
door panels will swap right over but you will need the handles and bezels from the new truck not sure if you need the Rods Grab them just in case.
_Dylan_
STAY FROSTY
you also need the metal panel that bolts to the door.
door panel and switches
metal door panel thingy (the name is escaping me right now)
inside handle
lock rods
wiring
Donnie Yukonie
Yates Caretaker
inside handle
lock rods
wiring
THIS ^^ i almost forgot , if you don't get this you won't be able to mount the new handle in its place or secure the rods my bad :angry94:
W
white_lexie
So I need the rods, panel and all acc, as well as the metal panel that bolts the window motor and tracks bolt up to?
Gzes
the drifting 2dr
Wichita tx
Only thing that might give you trouble is where door panel and dash meet when closing. The 94 dash is different than 95+ thats only thing everything else is no problem
dylansmashed
