95 chevy tahoe multi-function switch
Tahoe4x495
Hey everyone sometimes my intermittent settings for my wipers mess up and work in sync same with my cruise control, it works sometimes and then it doesn't. I researched and found that it could most likely be a faulty multi-function switch but I was seeing if anybody had any other suggestions. Thanks
BennyR72
Los Angeles, CA
When you say "work in sync same with my cruise control" do you mean that when you switch on your CC your wipers turn on as well, or do you mean that the whole switch will work intermittently?
T
Tahoe4x495
The whole switch will work intermittently. Sorry I worded it weird.
BennyR72
Los Angeles, CA
Gotcha.
I had a similar issue but mine was turn signal related. If you feel so inclined, you can take the whole switch out and disassemble it. You'll see a small box on the end of the lever that (once you open it up) will have a bunch of little metal fin connection points. They get dirty, bent and misaligned over time, so you might just be able to move something back into place or clean it off. I used some canned air and denatured alcohol and cleaned those off and it fixed my problem.
If not, Amazon's got a pretty good price on the OEM replacement, and if it turns out to be something else, it's always a breeze to return stuff.
http://www.amazon.com/ACDelco-D826A-Equipment-Headlight-Windshield/dp/B000C9MN90/ref=sr_1_1?s=automotive&ie=UTF8&qid=1430002880&sr=1-1&keywords=ACDelco+D826A
Hope that works out.
T
Tahoe4x495
Thanks I'll try cleaning the connections and if that doesn't work I'll decide to go from there
Teninback
