95 tahoe cold engine knock under load
ERIC95TAHOE
Southern Wisconsin
like the title says my 95 tahoe has a cold engine knock, it only seems to happen under a load, it will last up to 5 minutes sometime depending how cold it is outside, but when warmed up half way, almost to, or at operating temp. its gone. my oil pressure is great. my truck has 188k miles on it, supposedly the engine only had 1000 miles or so on it when i bought it(i put about 5000 on it since then), i know its not the original engine, i dont know what year it is, normally every tahoe/blazer/yukon i came across around those years has a smaller longer oil filter mounded sideways. mine has the oil filter mounted up and down like the older chevy blocks only it takes a weird filter number that i never seen on a chevy lol. so anyone know whats going on? if you need more info let me know! thanks
96ProCompTahoe
IN
its a common thing on the vortec's 96+ could be the same thing.
mine does it on cool days. 184K on it. i just let it warm up a couple minutes and it goes away.
ERIC95TAHOE
ERIC95TAHOE
Southern Wisconsin
What number filter does your engine take??
ac delco filter number pf25 and pf454 apparently ive been using carquest filters and just recently had them crossrefrance it to an ac filter
yeah if i let it warm up first i have no problems, my problem is i get up last minute for work and dont get time for it to warm up lol
black95
Freeport,NY
my 95 took an acdelco PF52, and my truck always has a cold knock form day one, look into your timing and make sure it is right
---------- Post added at 08:29 AM ---------- Previous post was at 08:28 AM ----------
,but most likely it is just a factor of life, my 95 had 257,000 on the original motor and it always knocked and the only reason it is gone is it got totalled 3 weks ago
bowtiefreak
No Quarter
Near Philly
it's the correct weight per GMs spec. I run 10-40 most of the time....I dont run a 350 either
Gotcha12
