96 and earlier 4 door AC deal
Tbruz
Windham NH
Anyone rebuilding their 4 door ac system ...
I have a brand new AC Delco condensor and a AC Delco clutch fan that wont fit my 97 two door.
FAN CLUTCH pn is # 15-4553
CONDENSOR pn is # 15-6958
Both are ACDelco. $150 plus shipping gets you both
Thanks
Tbruz
MarkD51
Sheboygan Wisconsin
nope but i need to replace my orifice tube with a hot climate type one.
Sorry if I'm veering off topic in this thread, but please do let us know Sunlit C how that goes when you do such a swap?
I was afraid to try jamming this hi temp O-Tube in the line by the condenser because of the differences in size-appearance versus stock. (This hi temp version is differently shaped, and quite a bit longer I found)
Would like knowing if it indeed fit, and if any differences noted in AC efficiency?
SunlitComet
OBS Jedi-Do Good
unknown at this time.
not sure when i will get to it but a few here have done it with no ill will other then having to get the system apart in that area. usually seize line connections.
Jayhawkeye3
