96 Tahoe 4wd issue
the downlow
W Houston
their is a bulletin for 88-97 K1500s for this. The acuator on the front diff. was fluid acuated and they call to update it to the electic one for 97-up. you replace the acuator and there is a harness that has to be installed too to switch it. i can give you the bulletin number 76-43-01A
this is most likely your problem. cant say for sure without seeing it but this should give you a starting point.
jkiger95
